DDI on CCME
Hi team
How Can I configure DDI for CCME
My DDI Range 2303320-29
and me Phone Number 501 -509
Brgds
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: DDI on CCME
A nitpick: your DP 300 doesn't need port. port is never used for incoming DP.
Please remember to rate useful posts with the scrollbox below.
Re: DDI on CCME
hi there
just make incoing translation profile and apply it to your pots dial-peer
this one take only las three digits
and on each ephon-dn
creat a number with a secondary number
for eaxmple lets say call coming to last three digits 320 should go to extention 501
ephone-dn 1 dual-line
number 501 secondary 320
good luck
if helps Rate
Re: DDI on CCME
There are two methods, dialplan-pattern and translation rules. I recommend the second especially if you have CUE.
voice translation-profile makedid
translate called 10
voice translation-rule 10
rule 1 /230332/ /50/
voice-port x/y/z
translate incoming makedid
Re: DDI on CCME
Dear All
Problem solved
I add
voice translation-rule 506
rule 1 /21/ /501/
rule 2 /22/ /502/
rule 3 /23/ /503/
rule 5 /25/ /505/
voice translation-profile 506
translate called 506
voice-port 0/3/0
translation-profile incoming 506
dial-peer voice 3300 pots
incoming called-number .
direct-inward-dial
port 0/3/0
Re: DDI on CCME
Re: DDI on CCME
Great
Thank for yoy advice p.bevilac
Brgds
142
