DDI
Wer can I found information about how to configurin DID on the following scenary
Callmanager ver
H232 voice Gateway - E1 PRI
PTSN num - 2602300
Phone ext num 3xx
I want that when peopel call 2603301 it go to ext 301 and so
  • IP Telephony
Re: DDI
configure the GW as usual
on CCM significant digits set to 3
DNs using 3 digits
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: DDI
Its already done .But in wath concerning the VOice Gateway?
Before , I have a plar connection , but all the call came just to one Phone
Re: DDI
voip dial peer using the digits you expect to receive and send it to CUCM with session-target command
java
java
Re: DDI
Hi friend,
This is a good document for Understanding Direct-Inward-Dial (DID) on IOS Voice Digital (T1/E1) Interfaces:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00801142f8.shtml#back
Hope this info helps you!
Please rate useful posts.
Best regards,
- Adrián.
Re: DDI
Hi Adrian
I am using the foolowing dial-peer
dial-peer voice 300 voip
preference 4
destination-pattern .
session target ipv4:172.19.0.253
dtmf-relay h245-alphanumeric
codec transparent
But any all the ext ( from 301 to 399 ) are receiving the call direct fom outside.How can I block some ext to not receive a call ?
110
