DDTS CSCts63954 in CUC
Someone know if this bug also affects 8.6.2 ??
Also when is going to be fixed?
Carlo
In the CUC Release Notes:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/861cucrn.html
Note
Connection  8.6 versions of languages other than ENU are released. The Connection  server must be running a minimum of 8.6(1)ES2 to use these languages.
So the question is when the 8.6(1)ES2 is going to be available for the public, or else the Locales for 8.6.2 when they are going to be available?
Hall of Fame Super Red
Hi there,
The locale files for 8.6(2) have not been released yet
Note
Connection 8.6.2 version of languages other than ENU will be released soon.
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/connection/8x/release/notes/862cucrn.html#wp1300703
The 8.6(1)ES2 files are available for download (via path below) but won't work on 8.6(2)
Unity Connection Locale Installer-8.6(1)ES2
Cheers!
Rob
Hi Rob,
Thanks for the info, currently if you use CUC 8.6(1a) even with the locales 8.6(1)ES2, the locales won't show up. The fix must be in CUC, I would suspect that 8.6(1b) will be ES2, but there is no release date yet.
8.6.2 doesn't have this bug, but as you pointed out there are no locales either.
Hi Carlo,
Did you try opening a TAC case to see if they could load
up ES2 for special download for you?
Cheers!
Rob
Thanks Rob,
Yeap, that's what I did. TAC published an ES, but is not the ES2, it just contains the fix for the DDTS
i have cuc 8.6.2 and i install this locale uc-locale-pt_BR-8.6.2.1-25.cop.sgn but is does not appear for me to choose this language after a install
850
