Community Member
debug 3rd party sip endpoint
I'm facing a problem with 3rd party ip phone (Grand stream) with the CUCM v6 & CUCM v8.6
the ip phone is registered successfully but every time I choose custom ringtone from ip phone it doesnt change inspite of it appeared in the ip phone as chosen.
I need to know how to debug registration of that specific ip phone.
Community Member
Hey,Did you try to collect on
Hey,
Did you try to collect on RTMT SDL/SDI traces when you're appling the changes? Also collect TFTP traces from your servers.
Community Member
thank you rafamar2 for your
thank you rafamar2 for your reply
but I already tried RTMT but when view real time traces ,there is a lot of logs appeared I cant filter it to that specific ip phone
Community Member
Hi Mahmoud,You can do on this
Hi Mahmoud,
You can do on this way:
- On RTMT go to: System Tools TraceTrace Log & Central then click
-Collect the files for SDL/SDI and TFTP
- Download it to your laptop and use Notepad++ to search on the traces using specifc phones information such MAC Address, phone extension and so on.
Please let me know if it will help you
Rgds
Community Member
HiI found good way I'd like
I found good way I'd like to share
from cisco serviceability > trace > configuration
check " Device Name Based Trace Monitoring"
then select the specific device you want to trace it
then from RMTM you will find traces for that specific ip phone
105
