Debug ccsip Reason: Q.850;cause=38
Please help ASAP,i can't find a documentation on the solution for this code:
Here is the debug and Configuration
Received:
INVITE sip:5555317884@178.208.X.X;user=phone SIP/2.0
Via: SIP/2.0/UDP 188.254.68.66:9298;branch=z9hG4bK-6110d60075a24c0f-a3c000c-1
Call-ID: isbc6994325518768294927-1385194135-11717
From: <sip:9268854639@sipgw120.com;user=phone>;tag=sbc09106994325518768294927
To: <sip:5555317884@178.208.X.X;user=phone>
CSeq: 1 INVITE
Min-SE: 90
Session-Expires: 3600;refresher=uac
Contact: <sip:9268854936@188.254.68.66:9298;user=phone>
Allow: INVITE,CANCEL,BYE,ACK,REFER,UPDATE,INFO,PRACK
Supported: timer,100rel
Diversion: <sip:8002001706@sipgw120.com>;privacy=off;screen=no;reason=unknown,<sip:8002001706@sipgw120.com>;privacy=off;screen=no;reason=unknown
Max-Forwards: 70
User-Agent: VCS 5.8.2.56-03
Content-Length: 394
Content-Type: application/sdp
v=0
o=- 87852 198805 IN IP4 188.254.68.67
s=SBC call
c=IN IP4 188.254.68.67
t=0 0
m=audio 23682 RTP/AVP 8 0 18 98 96 97 101
a=rtpmap:98 G.729a/8000
a=rtpmap:96 G.729ab/8000
a=rtpmap:97 G.729b/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=fmtp:18 annexb=no
a=ptime:10
a=X-vrzcap:vbd Ver=1 Mode=FaxPr ModemRtpRed=0
a=X-vrzcap:identification bin=DSR2866 Prot=mgcp App=MG
00:43:23: //11/FDB448CE8020/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Sat, 23 Nov 2013 08:06:29 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 503 Service Unavailable
From: <sip:9268854936@sipgw120.com;user=phone>;tag=sbc09106994325518768294927
c2801#er=phone>;tag=27BA64-1DAE
CSeq: 1 INVITE
Content-Length: 0
00:43:23: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:5555317884@178.208.X.X;user=phone SIP/2.0
To: <sip:5555317884@178.208.X.X;user=phone>;tag=27BA64-1DAE
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
show run:
voice service voip
ip address trusted list
  ipv4 87.226.136.164 255.255.255.255
  ipv4 172.16.24.0 255.255.255.0
  ipv4 188.254.68.66 255.255.255.255
  ipv4 188.254.68.67 255.255.255.255
  ipv4 188.254.69.66 255.255.255.255
  ipv4 188.254.69.67 255.255.255.255
  ipv4 46.38.52.68 255.255.255.255
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
sip
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice class codec 2
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 1
rule 1 /XXX5397962/ /1999/
voice translation-rule 2
rule 1 /XXX55317577/ /1999/
voice translation-rule 3
rule 1 /5555317884/ /1999/
voice translation-profile ROS
translate called 1
voice translation-profile ROS2
translate called 2
voice translation-profile ROS3
translate called 3
interface FastEthernet0/0
ip address 178.208.X.X 255.255.255.248
ip access-group INBOUND in
no ip unreachables
ip verify unicast reverse-path
ip nat outside
ip inspect IPFW in
ip inspect IPFW out
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.110.0.200 255.255.255.0
ip nat inside
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 172.16.24.254 255.255.255.0
ip nat inside
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.24.254
ip dns server
ip nat inside source list NAT interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 178.208.X.X
ip route 192.168.0.0 255.255.0.0 Null0 254
sccp local FastEthernet0/1.2
sccp ccm 172.16.24.101 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register XCODE123456
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 6
associate application SCCP
dial-peer voice 10000 voip
tone ringback alert-no-PI
description ROSTELECOM Incoming
translation-profile incoming ROS
destination-pattern 74955397962
session protocol sipv2
session target ipv4:87.226.136.164
session transport udp
incoming called-number XXXX5397962
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 10010 voip
translation-profile incoming ROS2
destination-pattern XXX55317577
incoming called-number 75555317577
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 10020 voip
translation-profile incoming ROS3
preference 1
destination-pattern 5555317884
session target ipv4:188.254.68.66
incoming called-number 5555317884
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 10021 voip
preference 2
session target ipv4:188.254.69.66
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2 voip
description to CUCM_PUB
destination-pattern 1...
session target ipv4:172.16.24.101
voice-class codec 2
dtmf-relay rtp-nte
I see in the debug that the itsp over g729 family codecs but not g711 at all
This system was working with this dialpeers before with same provider ,just i have added the dial-peer 2 .
I have changed the codec to match what is offered by itsp but no difference,still getting the same message.
PLZ help ASAP.
1 REPLY
Re: Debug ccsip Reason: Q.850;cause=38
Please add the debug ccsip all.
Regards.
846
