Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
debug CME question
Hi all,
When I do the debugging on CME (debug voice ccapi inout, debug h225 Q931), I see the debugging , but don't know how to easily see who sends which message (for example is the disconnect initiated by the CME or by the TSP)
in particular :
Data 0528501900060008914A000400022E7F815D60361326095634343434EF10A00100140140B50000120D80A2000943004C050000333839
Q931 Message IE Decodes
Protocol Discriminator : 0x08
CRV Length : 2
CRV Value : 0x751F
Message Type : 0x5A: RELEASE_COMP
Cause: Length Of IE=2
Data 8083
User-User: Length Of IE=29
Data 050580060008914A0004011100022E7F815B98281725505634343434EF
CRV Length : 2
CRV Value : 0xF51F
Data 8083
User-User: Length Of IE=34
Data 052580060008914A000411001100022E7F815B98281725505634343434EF10800100
CRV Length : 2
CRV Value : 0x7EDB
Data 8083
Data 050580060008914A0004011100022E7F815D60361326095634343434EF
CRV Length : 2
CRV Value : 0xFEDB
Data 8083
Data 052580060008914A000411001100022E7F815D60361326095634343434EF10800100
or
*Sep 4 10:56:34.392: vsacount in free is 2
*Sep 4 10:56:38.256: //13692/4EE0E727B56A/CCAPI/cc_api_call_disconnected:
Cause Value=3, Interface=0x46DCEED0, Call Id=13692
*Sep 4 10:56:38.260: //13692/4EE0E727B56A/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=3, Retry Count=0)
*Sep 4 10:56:38.260: //13692/4EE0E727B56A/CCAPI/ccConferenceDestroy:
Conference Id=0x111B, Tag=0x0
*Sep 4 10:56:38.260: //13692/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x111B, Source Interface=0x46DCEED0, Source Call Id=13692,
Destination Call Id=13693, Disposition=0x0, Tag=0x0
*Sep 4 10:56:38.260: //13693/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Conference Id=0x111B, Source Interface=0x477FCEB4, Source Call Id=13693,
Destination Call Id=13692, Disposition=0x0, Tag=0x0
*Sep 4 10:56:38.260: //13692/4EE0E727B56A/CCAPI/cc_generic_bridge_done:
Any suggestions are most welcomed
Best regards
Goran Pilat
Re: debug CME question
Hi Goran,
These debugs do not tell you the direction.
What will is: debug h225 asn1
I think it's fairly likely that it is your CME disconnecting because cause value 3 is 'No Route to Destination'. Basically the number you're receiving doesn't match an ephone or dial peer.
I would check 'debug voip ccapi inout' again the dest= in the debugs. Then use a 'show dial-peer voice summary' to see what your system is showing the dial peers as. Check for any translation problems on the incoming and outgoing dial peer.
-nick
Hello Nick,
Thanx for the reply. However, the problem is solved and the TSP took responsibility. The above traces happened sporadically, in the middle of conversation, sometimes didn't happen and so on... ghostbusters stuff...
The problem was in their core and now everything seems to be ok.
Thanks for the "debug h225 asn1", anyway.
Best regards
Goran Pilat
607
