Debug mmoip send email
i am trying to configure store and forward fax, but the problem is that the email is not sent.
"Debug mta send all" and "Debug mmoip send email test@10.10.10.10" do not show any output.
Best regards,
Marko
Silver
Re: Debug mmoip send email
The debug mmoip send email address command does not display anything to the screen itself, but it is very useful. It uses the router as an SMTP client to send an email to the address given in the debug command. The email has the subject defined in the configuration and is from "mspi Test User". It contains a text attachment with the line, "This is a test email message sent via Cisco Powered Libretto Faxmail."
http://www.cisco.com/en/US/customer/tech/tk652/tk777/technologies_tech_note09186a00801fe5d
Solved this by using debug fax foip command, which indicated domain name error when sending the email.
Cheers,
Marko
516
