debug translation
Can someone give me any insight as to what may be causing calls not to go through. I posted a snippet of a debug. Thanks.
*Jun 26 17:18:23.515: //75/00CC1EB05B01/CCAPI/ccCallCanGateway:
CALL_ERROR_INFORMATIONAL; Gateway Is Not Allowed;
Incoming InterfaceType=1, Outgoing Interface Type=28, Call Id=0x4B
*Jun 26 17:18:23.515: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
*Jun 26 17:18:23.515: : updating existing feature vsa
*Jun 26 17:18:23.515: feature call basic
*Jun 26 17:18:23.515: //75/00CC1EB05B01/CCAPI/ccCallDisconnect:
Cause Value=3, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Start Calling Accounting;
Call Entry(Incoming=TRUE)
Cause Value=3, Call Entry(Disconnect Cause=0)
Cause Value=3, Call Entry(Responsed=TRUE, Cause Value=3)
Re: debug translation
I need the entire debug voip ccapi inout and the whole config. also if its a pri debug isdn q931
Thanks!
Chad
that cause is
No route to destination
it's all i can tell from your post
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
358
