debug voice ccapi inout
dbenattou
hello,
i user some debug using the debug voice ccapi inout, the disconnect value is 34.What this value means ?
virverma
Level 4
Level 4
The call is failing on the ISDN leg with cause = 34, which means no circuit
available
Could be issues with port that it is not configured properly where the call is going
useful link
Using Call Flows to Resolve Call Processing Problems
http://www.cisco.com/iam/unified/ipt611/Using_Call_Flows_to_Resolve_Call_Processing_Problems.htm
java
if this helps, please rate
java
hello
BUT THE cofig is simple and requires just the connection plar opx and the dial-peer voice XXX voip to the ccm.
Thanks for help
