debug voice dialpeer detail
Hi all,
In my lab, I make test call from 8001---> gw-->cucm---> 2005 . I debug in the gateway and see that  called number (2005) are changing into calling number and then to called number. Any body clarify for me?
Ro_BR1#debug voice dialpeer detail
voip dialpeer detail debugging is on
Ro_BR1#
Aug 27 2013 08:00:34.431 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=8001
Aug 27 2013 08:00:34.431 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Aug 27 2013 08:00:34.431 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=8001T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=8001
Aug 27 2013 08:00:34.431 UTC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=20001 Is Matched
Aug 27 2013 08:00:34.455 UTC: //-1/95FE800E81D4/DPM/dpMatchCore:
   Dial String=2, Expanded String=2, Calling Number=
   Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 27 2013 08:00:34.455 UTC: //-1/95FE800E81D4/DPM/MatchNextPeer:
   Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=301
   Result=1
Aug 27 2013 08:00:34.655 UTC: //-1/95FE800E81D4/DPM/dpMatchCore:
   Dial String=20, Expanded String=20, Calling Number=
Aug 27 2013 08:00:34.655 UTC: //-1/95FE800E81D4/DPM/MatchNextPeer:
   Result=1
Aug 27 2013 08:00:34.855 UTC: //-1/95FE800E81D4/DPM/dpMatchCore:
   Dial String=200, Expanded String=200, Calling Number=
Aug 27 2013 08:00:34.855 UTC: //-1/95FE800E81D4/DPM/MatchNextPeer:
   Result=1
Aug 27 2013 08:00:35.055 UTC: //-1/95FE800E81D4/DPM/dpMatchCore:
   Dial String=2005, Expanded String=2005, Calling Number=
Aug 27 2013 08:00:35.055 UTC: //-1/95FE800E81D4/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=301 Is Matched
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Aug 27 2013 08:00:35.059 UTC: //-1/95FE800E81D4/DPM/MatchNextPeer:
Aug 27 2013 08:00:35.059 UTC: //-1/95FE800E81D4/DPM/dpMatchCore:
Aug 27 2013 08:00:35.059 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=2005, Expanded String=2005, Calling Number=2005T
Aug 27 2013 08:00:35.059 UTC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Aug 27 2013 08:00:35.059 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=2005
Aug 27 2013 08:00:35.059 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=2005T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=2005
   Result=Success(0); Incoming Dial-peer=301 Is Matched
Aug 27 2013 08:00:35.063 UTC: //-1/95FE800E81D4/DPM/dpMatchCore:
Aug 27 2013 08:00:35.063 UTC: //-1/95FE800E81D4/DPM/MatchNextPeer:
Aug 27 2013 08:00:35.103 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=0963100136, Expanded String=0963100136, Calling Number=
   Result=-1
Aug 27 2013 08:00:35.103 UTC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Ro_BR1#
Aug 27 2013 08:00:53.591 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Aug 27 2013 08:00:53.595 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Aug 27 2013 08:00:53.595 UTC: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Aug 27 2013 08:00:54.435 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=2...
Aug 27 2013 08:00:54.435 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Aug 27 2013 08:00:54.435 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=2...T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=2...
Aug 27 2013 08:00:54.439 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
Aug 27 2013 08:00:54.439 UTC: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Match Rule=DP_MATCH_ANSWER; Calling Number=8001$
Aug 27 2013 08:00:54.439 UTC: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=8001$T
   Result=-1
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=8001$
   Result=-1
Ro_BR1#
Ro_BR1#
Ro_BR1
Thuc
What are you trying to test?
Do calls to 2005 dont work?
Tapan
Hi.
This happens because voice gateway is doing a digit match for incoming dialpeer for called number to complete the second call leg.
In this case if a dialpeer with answer-address 2005 was configured, voice gateway would match that DP.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
I don't have answer-address dial-peer. Maybe, It is matched another dial-peer which has destination-pattern or incomming called, right?
Hi Tapan,
it is successfull. I just want to understand the output debug command.
Thuc
Hi Thuc.
Because you don't have any dial-peer with answer address, VG goes on using incoming and outgoing matched DP... in your case
Incoming=20001
Outgoing=301.
As I mentioned, what you see is only a check that VG does to verify if a more specific dialpeer exists in the following order:
1) Incoming called-number
2) Answer-address
3) destination-pattern
If none of the above is matched, VG try to use the default DP 0 which, as you know, uses codec g729.
Carlo
Hi Carlo,
I understand that incoming dialpeer and outgoing dialpeer are 20001 and 301. But After outgoing dialpeer is matched, it seem to match again. Pls see:
   Result=-1
Could you clarify for me? What is Match Rule=DP_MATCH_ORIGINATE?
Thuc
330
