Community Member
Dedicate Channels
I have a 2911 Gateway using Isdn PRI E1 connection.
I want to be able to dedicate one of the channels for 1 incoming/outgoing number only.  (This will be a fax line) The other channels can be first come first served
I am thinking this can be done, but I cannot find any examples in docs to show the config.
I guess I need to divide the timelots into groups and have seperate dial peers etc?
1 ACCEPTED SOLUTION
Re: Dedicate Channels
Not sure why you want to do this but yes, you should be able to split
the PRI for such purposes but there are few caveats:
- For Chan1 that u want to dedicate for fax, you'll have to ask
  your telco(ISDN provider) to assign it a dedicated DID for inward
  calls.
- Telco should not be routing that DID on any other channel except 1.
- You may need some translations/digit manipulation and/or prefix
   dialing to differentiate the two type of calls which users may find
   inconvenient.
Here's an example on how to split a PRI...use it as a guideline and
modify things as per your requirments and dial plan...
controller E1 1/0
pri-group timeslots 1-31
trunk-group FAX timeslots 1
trunk-group VOICE timeslots 2-30
dial-peer voice 1 pots
incoming called-number .  <--hardcode fax DID being rec. from telco
direct-inward-dial
trunkgroup FAX
description - FAX : access code 77
destination-pattern 77T
dial-peer voice 2 pots
direct-inward-dial
trunkgroup VOICE
description - VOICE : access code 78
destination-pattern 78T
In this case, FAX user would dial 77 as an access code and VOICE users would dial 78.
These access codes would 'steer' the call to the appropriate timeslots on the PRI.
Since your case is simpler, u can use another prefix like a 7 or 8 when u dialing from
the fax and let all others dial 9 for outside as usual.
This could be enhanced using Class Of Restrictions (COR) to prevent users dialing out each
other's channels on the PRI.
HTH,
DK
Hall of Fame Super Gold
Do you actually anticipate that alls 30 channels can go busy ? How many users do you have ? How long you had this in service to make sch an assumption ?
  calls.
   inconvenient.
controller E1 1/0
direct-inward-dial
trunkgroup FAX
direct-inward-dial
trunkgroup VOICE
HTH,
DK
Community Member
Thanks Dilip that's exactly what I need.
Please note that the above sugestion will only work for outgoing calls from router to PSTN.
You cannot control the channel for incoming calls, as it will be always dictated by the switch.
That leads to the following scenario;
1. your users orignate 29 calls as allowed by trunk-group definition
2. A 30th call comes in, it voice not fax and must be accepted.
3. 31th call comes in, fax call, but all channels are now busy.
Also note from above suggstion:
No telco in the world will even consider such a request !
What you want to do, is not easily doable !
Yes, GW/IOS side has no control over which channel the
incoming call comes in on and hence those caveats.
It can be done as long as the PRI is ordered properly.
Switches are programmable and do let u split the PRI
in group(s) of DS0s and assign a DID or a range of DID.
As long as telco can fulfil that, the config will work fine.
I stand my statement by experience:
No telco in the world will make any special channel arrangement on PRIs.
If you have a real expereince otherwise, post it here.
Yes, I can say that I have helped both telco and customers
configure such feature in the past. Not common at all but
doesn't mean that if we have not seen something its not
happening.
Let's await for the OP to report on his experience asking a special channel arrangment in his country.
Community Member
I agree... most telcos aren't very accommodating unless you just happen to get someone in a higher level support position that's knowledgeable and willing to help you. I wouldn't say impossible, but certainly uncommon.
Honestly, if the OP has that high of a need for a dedicated fax line, wouldn't they be better off having a simple copper line attached to an FXO port and go from there?
315
