Default class in QOS
ciscoroyzhang
Hi all
I am new to QOS,  need a help on how to setup default class.
in following example, I know that trafic with dscp 0 will be placed in fair-queue, but what about packet with other DSCP value apart from CS3/EF. is there any command to reset all other packets to default value.
)# class-map match-any    VOIP-RTP
)# match dscp ef
)# class-map match-any    VOIP-CONTROL
)# match dscp cs3
)# policy-map          VOIP-QOS-POLICY-OUT
)# class VOIP-RTP
)# priority bandwidth 90
)# class VOIP-CONTROL
)# bandwidth 30
)# class class-default
)# fair-queue
)# int s0/2/0:0
)# service-policy output VOIP-QOS-POLICY-OUT
Thanks.
Roy
ciscoroyzhang
find answer:   Each class is evaluated in the order they were put into the policy-map and the last class in the policy-map is always the class-default. The class-default is in every policy-map by default and it cannot be removed. The class-default has a classification policy that matches all traffic that has not been identified by any other class in the policy
details:
http://www.networkworld.com/community/node/38627
Correct, basically all other markings will be stripped and traffic will go into default queue with DSCP 0.
HTH,
Chris
