Community Member
Default configuration file for IP phones
I have a call manager express and some 7911 IP phones which are using the default configuration file (firmware). I tried to connect a 7942 to the network it registers with the CCME but it's enable to get the DN I 've assigned to it. What should I do to fix the problem.
1 REPLY
Hall of Fame Super Gold
Re: Default configuration file for IP phones
1. configuration files is NOT firmware.
2. cannot understand your problem. Can you explain in different words ?
127
