default directory handler
All, how do I go about getting the default directory handler to have a list of names? I would like to have all names in the default, so that when a caller has the option of dialing by name, they can simply dial a few letters of the name and it recognize who they want. I have the cti route point poiting to the extenstion, which callforwardall to voicemail, which says "there are no names in the diretory"? How do I get the name in the directory?
1 ACCEPTED SOLUTION
Re: default directory handler
do all the subscribers have their recorded name? that's mandatory?
The handler is pointing to the whole list of subscribers or to a PDL?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
When I have it play all names, thats when it tells me "there are no names in the directory".
javalenc
java
No recorded name. Let me try that and see what happens. They are pointed to the whole list. Will let you know.
Thanks, the recorded name solved the issue. I appreciate the knowledge share.
125
