Default idle URL for phones on CUCM 10
Need to know the default URL Idle parameters for self provisioning. I deleted it and forgot to take a copy and can't find it documented anywhere. Any help would be greatly appreciated!
Not sure what you're asking,
Not sure what you're asking, self provisioning does not require an idle url
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/10_0_1/ccmcfg/CUCM_BK_C95ABA82_00_admin-guide-100/CUCM_BK_C95ABA82_00_admin-guide-100_chapter_01101001.html
java
if this helps, please rate
www.cisco.com/go/pdi
I already have self
I already have self provisioning setup with PLAR. For phones that can display the login screen there is a Idle URL under Enterprise Parameters.
Maybe this one:
Maybe this one:
https://x.x.x.x:443/cucm-uds/xps/selfProvision
java
I hit this on a new cluster
I hit this on a new cluster on 10.5 - the Idle URL enterprise param wasn't set.  I enabled auto-reg, phone registered but kept trying to query https://ucmpub/cucm-uds/xps/selfProvision, which came up with an error.
Setting the service param did not resolve the issue.  I noticed that this was getting hard-coded into the phone's config.  I traced this back to the Universal Device Template's configuration.  It's another step to change when setting up a new cluster I guess?
In User Management -> User
In User Management -> User/Phone Add -> Universal Device Template  there is an "Auto-registration Template" created automatically with a certain Idle URL. This template is used by default when auto-registering. So change this, or change the Universal Device Template used when auto-registering.
I got the same issue when I changed the hostname of my server.
However I haven't already found a good URL to provide for having an Idle screen
1438
