Community Member
Default MOH files
Hello, I am working an older Call Manager System 4.0 and found that when it was installed it was installed with only one "The Boys from Liverpool" MOH file. Which now one here likes and of course I open my mouth and tell them there should be other choices. NOT!
Does anyone know the link to download the basic comes with the systems MOH files?
Thanks for the help.
Jon
1 ACCEPTED SOLUTION
Re: Default MOH files
Jon,
Older versions of CCM shipped with an MoH Selections CD which contained a range of tracks including Boys from Liverpool.
From memory Cisco announced that they would no longer be shipping this CD with new versions of CCM as they were constantly being pursued by the Performing Rights Society for royalties despite the fact that Cisco had actually commissioned and paid for the tracks.
If you cannot find the CD you can download royalty free tracks from sites such as:
http://www.royaltyfreeclassicalmusic.co.uk/
You may need to convert the file format for use by CCM. I use Switch Sound File Converter from NCH Software for this purpose.
http://www.nch.com.au/switch/index.html
Please rate if helpful.
Hall of Fame Super Red
Hi Jon,
Try the last one on this page (these are the only ones available still for download) :)
http://www.cisco.com/pcgi-bin/swsrch/SWSearch_results.cgi/SWSearch_results.cgi/SWSearch.txt?isChild=false&file_delimiter=contains&searchPhrase=music
Hope this helps!
Rob
Jon,
Community Member
jamesha,
Thank you for the reply. I did pretty much as you said and found royalty free music that I was able to download and then used exactly the program you recommended. Thank you again for you help.
Jon
2161
