default pass
Is there any default password for users trying to logon to https://callmanager/ccmuser ?
It will take ages to create passwords for every user using the callmanager administration.
Thank you.
Re: default pass
12345 don't work :(
Re: default pass
which table in callmanager database contains users&passwords entries?
Re: default pass
there is no default password, if you're using DCD when you created each user the pwd was a required field you needed to enter
if you're integrated with AD then they're using the credentials from the directory and in order to change them you need to log into AD
the users are not in the CUCM DB, they're in the directory to which you're integrated
java
if this helps, please rate
www.cisco.com/go/pdi
312
