Delay dialing for any number in UCM 6.0
First, I am pleased to join you --- the problem in front of me that the length of call time when dial any number for International or local whatever, the dialing number take arround 25 to 28 second to call the number , so please your advice about this problem
1 REPLY
Re: Delay dialing for any number in UCM 6.0
Have you looked at your dial plan for any overlapping that could be causing this?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
148
