Delay in Dialing extentions after conversion from 4-to-5-digits
We have a CCM Setup with 4 digits extensions which we converted to 5-digits extentions due to customer requirement. The customer also wanted the 4-digit and 5-digit extention co-existentfor some time, so that the callers calling 4-digit can also reach new 5-digits extentions.Voice Gateways use MGCP.
Following steps were followed:
1.Modified existing translation rule to convert incoming calls look for 5 digits IP Phones extn(instead of earlier 4-digits).
2.Added translation rule to convert 4-digit extentions to 5-digits for people dialing internally(in case caller still dials 4-digit extension).
3.Already converted all existing IP Phone 4-digit extentions to 5-digits.
Now we get a delay on dialing 4-gits extentions(as I believe the CCM waits for interdigit timeout), unlike earlier when there was no delay.
Can somebody suggest to get RID of this delay, with both 4 & 5 digit extension co-existing.
Bronze
Re: Delay in Dialing extentions after conversion from 4-to-5-dig
There are two ways that I can think of:
Prevent digit overlap between 4 and 5 digit extensions. I think you can control this by use of Partitions and Calling search spaces. Are the 4 and 5 digit extensions in the same partition?
Have the users use the # sign after they dial 4 digit extensions.
the only way is to have a unique dial plan and do not have overlapping extensions. OR use CSS and partitions to only reach 4 digits or 5 digits but not both.
if you don't, it's expected and documented that it will happen so the system is Working As Designed
you can only try to lower the T_302 IDT value
it's all explained in the SRND dial plan chapter.
java
if this helps, please rate
java
www.cisco.com/go/pdi
116
