Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Delete Default Background on 7965
How can I delete the default background on the 7965\7945 phones? We have uploaded a new corporate image and its the only pic in the list.xml file but the phone shows the default and the new background image.  We need to remove the default so the only option is the new corporate image background. Any ideas?  Thanks
Everyone's tags (2)
Re: Delete Default Background on 7965
You cannot, it's built in the FW of the phone.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Can't be done I'm afraid, although we have requested it via the BU as an enhancement request.
I am currently investigating voipintegrations Background deployment, which allows you to force the background to the changed on phones by model, clusterwide, device pool, or individually, although users can change it back themselves should they want to. Not bad value for $89, and seems OK so far.
Our only downsides so far are, it does not support 7906/11 phones, as these represent 75% of our deployment, and it's Windows Only.
Cheers,
Alistair
Is there anyway to modify the firmware file and replace the existing default image?
I do not believe this is possible.  As noted previously there is no admin push tool natively available on the CUCM or phone firmware.  You have two choices.  Put together a tool that will push the image for your or use a 3rd party application like the one referenced earlier in this thread.
I had to research something like this before and I did a write up on it here.  Maybe it will give you some ideas:
http://www.netcraftsmen.net/resources/blogs/pushbackgroundtoipphone.html
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
No, the FW is signed. So even if you could somehow modify the image it wouldn't be accepted by the phone.
Not to mention this wouldn't be supported.
If you also want this, i'd recommend you to get in touch with your AM and submit a PER
java
java
1400
