Denmark Numbering Plan for CallManager
Any ideas about where I can find a Denmark based Numbering Plan for the CallManager ?
Thank you in advance
Best regards,
Pan
2 ACCEPTED SOLUTIONS
Re: Denmark Numbering Plan for CallManager
always mention what version you're using
Deploying Dial Plans for 5.0(1) and Later\r\nReleases
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/idp/504_423/deploy/DPLinux.html
i did a quick search there but couldn't find Denmark DP. is it a normalized dial plan?? or is it like German DP?? if it's like German dial plan we don't have any since we only create it for normalized dial plans
java
if this helps, please rate
java
www.cisco.com/go/pdi
Super Bronze
I recently did a deployment in Denmark; I couldn't find a Cisco IDP for that country.
I used this Wikipedia link to construct my route patterns manually; no complaints yet from the users!
http://en.wikipedia.org/wiki/%2B45
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
java
java
Super Bronze
Aaron
Thank you for your feedback.
Yes I stumbled across that url as well.
Good to know that you have actually made
an implementation on this.
Thanks again for your time
Best regards,Pan
565
