Destination Pattern for Inter-branch VOIP
Hi ALL,
I have installed 2 Cisco CME in HQ and branch.
HQ is using extension 456, 457, 458, etc
Branch is using extension 50, 51, 52, etc.
When calling out, I would like to add a digit in front of extension or # behind extension to avoid extension conflict.
For example: HQ - 6456, 6457 or 456#, 457#
                      Brach - 750, 751, or 50#, 51#
How do I configure the destination-pattern?
Thank you.
2 ACCEPTED SOLUTIONS
i dont see a reason to use
i dont see a reason to use prefix , as both the branches are in different ranges
but if you still think you need to prefix , you need to use translation profiles to modify the digits
you have not configured
you have not configured destination-pattern in the dial-peer
add , destination-pattern 7..
I have tried below but still
I have tried below but still cannot
voice translation-rule 20
rule 1 /^7/ //
voice translation-profile vm
translate called 20
dial-peer voice 1000 voip
 translation-profile outgoing vm
 session protocol sipv2
 session target ipv4:192.168.218.11
 dtmf-relay rtp-nte
 codec g711ulaw
2911_CME#test voice translation-rule 20 758
Matched with rule 1
Original number: 758    Translated number: 58
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Still same.dial-peer voice
Still same.
 dtmf-relay rtp-nte
 codec g711ulaw
what are you dialing , 758
what are you dialing , 758 ?
enable below and send the logs with the call details
deb voip ccapi inout
deb ccsip mess
Yes, I am dialing 758.Oct  8
Oct  8 06:54:04.811: //-1/BA1E96388B54/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=468
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Oct  8 06:54:04.811: //-1/BA1E96388B54/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x23CA21AC, Call Info(
   Calling Number=468,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20009, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Oct  8 06:54:04.811: //-1/BA1E96388B54/CCAPI/ccCheckClipClir:
   In: Calling Number=468(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=468(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Oct  8 06:54:04.811: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct  8 06:54:04.811: :cc_get_feature_vsa malloc success
Oct  8 06:54:04.811:  cc_get_feature_vsa count is 3
Oct  8 06:54:04.811: :FEATURE_VSA attributes are: feature_name:0,feature_time:1051961384,feature_id:1169
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=468(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/cc_process_call_setup_ind:
   Event=0x22B280C8
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/ccCallSetContext:
   Context=0x3EB4D0BC
   >>>>CCAPI handed cid 982 with tag 20009 to app "_ManagedAppProcess_Default"
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/ccCallSetupAck:
   Call Id=982
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=982
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/ccCallReportDigits:
   (callID=0x3D6, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=982
Oct  8 06:54:04.811: //982/BA1E96388B54/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23CA21AC, callID=0x3D6, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x23CA21AC, Call Id=982
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
Oct  8 06:54:07.671: //982/BA1E96388B54/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=982, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x13426B8, Rtp Expiration=0x0
Oct  8 06:54:07.671: //982/BA1E96388B54/CCAPI/cc_api_call_digit_end:
   Source Call Id=982, Digit=7, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Oct  8 06:54:07.995: //982/BA1E96388B54/CCAPI/cc_api_call_digit_begin:
   Source Call Id=982, Digit=5, DigitBeginFlags=0x0,
   Rtp Timestamp=0x134A3B8, Rtp Expiration=0x0
Oct  8 06:54:07.995: //982/BA1E96388B54/CCAPI/cc_api_call_digit_end:
   Source Call Id=982, Digit=5, Duration=100,
Oct  8 06:54:08.235: //982/BA1E96388B54/CCAPI/cc_api_call_digit_begin:
   Source Call Id=982, Digit=8, DigitBeginFlags=0x0,
   Rtp Timestamp=0x13520B8, Rtp Expiration=0x0
Oct  8 06:54:08.235: //982/BA1E96388B54/CCAPI/cc_api_call_digit_end:
   Source Call Id=982, Digit=8, Duration=100,
Oct  8 06:54:08.235: //982/BA1E96388B54/CCAPI/ccCallReportDigits:
   (callID=0x3D6, digit_event=0x0, enable=FALSE, consume=FALSE)
Oct  8 06:54:08.235: //982/BA1E96388B54/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23CA21AC, callID=0x3D6, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Oct  8 06:54:08.235: //982/BA1E96388B54/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Oct  8 06:54:08.239: //982/BA1E96388B54/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1000, Params=0x3EB5A76C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Oct  8 06:54:08.239: //982/BA1E96388B54/CCAPI/ccCheckClipClir:
   Destination Pattern=7.., Called Number=58, Digit Strip=FALSE
   Called Number=58(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Conference Room 468
   Account Number=, Final Destination Flag=FALSE,
   Guid=BA1E9638-4DEE-11E4-8B54-9990DEF25B97, Outgoing Dial-peer=1000
Oct  8 06:54:08.239: //982/BA1E96388B54/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=468
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=58
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Oct  8 06:54:08.239: //982/BA1E96388B54/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3D462498, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=468,(Calling Name=Conference Room 468)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=58(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1000, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Oct  8 06:54:08.239: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Oct  8 06:54:08.239: :cc_get_feature_vsa malloc success
Oct  8 06:54:08.239:  cc_get_feature_vsa count is 4
Oct  8 06:54:08.239: :FEATURE_VSA attributes are: feature_name:0,feature_time:1051958248,feature_id:1170
Oct  8 06:54:08.239: //983/BA1E96388B54/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Oct  8 06:54:08.239: //983/BA1E96388B54/CCAPI/ccCallSetContext:
   Context=0x3EB5A71C
Oct  8 06:54:08.239: //982/BA1E96388B54/CCAPI/ccSaveDialpeerTag:
Oct  8 06:54:08.239: //983/BA1E96388B54/CCAPI/cc_api_call_proceeding:
   Interface=0x3D462498, Progress Indication=NULL(0)
Oct  8 06:54:08.243: //983/BA1E96388B54/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:58@192.168.218.11:5060 SIP/2.0
Via: SIP/2.0/UDP 10.184.1.201:5060;branch=z9hG4bK3E61862
Remote-Party-ID: "Conference Room 468" <sip:468@10.184.1.201>;party=calling;screen=no;privacy=off
From: "Conference Room 468" <sip:468@10.184.1.201>;tag=2351612C-43A
To: <sip:58@192.168.218.11>
Date: Wed, 08 Oct 2014 06:54:08 GMT
Call-ID: BC2A4589-4DEE11E4-8B599990-DEF25B97@10.184.1.201
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3122566712-1307447780-2337577360-3740425111
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1412751248
Contact: <sip:468@10.184.1.201:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 271
v=0
o=CiscoSystemsSIP-GW-UserAgent 4730 9954 IN IP4 10.184.1.201
s=SIP Call
c=IN IP4 10.184.1.201
t=0 0
m=audio 16570 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Oct  8 06:54:08.271: //983/BA1E96388B54/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Wed, 08 Oct 2014 06:52:51 GMT
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.2.4.M4
Content-Length: 0
Oct  8 06:54:08.275: //983/BA1E96388B54/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 Forbidden
To: <sip:58@192.168.218.11>;tag=6CE426C-1ACC
CSeq: 101 INVITE
Reason: Q.850;cause=21
Content-Length: 0
Oct  8 06:54:08.275: //983/BA1E96388B54/CCAPI/cc_api_call_disconnected:
   Cause Value=57, Interface=0x3D462498, Call Id=983
   Call Entry(Responsed=TRUE, Cause Value=57, Retry Count=0)
Oct  8 06:54:08.275: //982/BA1E96388B54/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Oct  8 06:54:08.275: //983/BA1E96388B54/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=983
Oct  8 06:54:08.275: //983/BA1E96388B54/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=57)
   Cause Value=57, Call Entry(Responsed=TRUE, Cause Value=57)
Oct  8 06:54:08.275: //983/BA1E96388B54/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3D462498, Tag=0x0, Call Id=983,
   Call Entry(Disconnect Cause=57, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Oct  8 06:54:08.275: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct  8 06:54:08.275: :cc_free_feature_vsa freeing 3EB39BE0
Oct  8 06:54:08.275:  vsacount in free is 3
Oct  8 06:54:08.275: //982/BA1E96388B54/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Oct  8 06:54:08.275: //982/BA1E96388B54/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Oct  8 06:54:08.279: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:58@192.168.218.11:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Oct  8 06:54:15.771: //982/BA1E96388B54/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x23CA21AC, Tag=0x0, Call Id=982,
Oct  8 06:54:15.771: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Oct  8 06:54:15.771: :cc_free_feature_vsa freeing 3EB3A820
we are receiving 403 from the
we are receiving 403 from the other cme
do you have the logs and config of the other cme for the same call ?
Received:
CSeq: 101 INVITE
Content-Length: 0
It is working now after
It is working now after adding destination pattern at remote site.
Thank you very much.
56
