Detailed Phone Logging
Is there a way to turn on detailed phone logging so I can see what a phone is doing and what keys are pressed? If so, how do I do it and how do I view the log?
Thanks.
1 ACCEPTED SOLUTION
Re: Detailed Phone Logging
yes, a CUCM detailed trace can give you those details. not what the phone is doing but what keys are pressed and states like going on-hook, off-hook, etc
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
115
