Determine H323 version
Can anyone tell me how to determine which versin of H323 is running on the gateway.
We are having intermttant problems with one way audio after being on-hold. I read Cisco's document regarding this issue and they recommend checking "Media Termination Point Required" in the Gateway options of CCMAdmin.
After further research, I found that this option only needs to be checked if H323 does not support hold and transfer features. I gathered from my reading that the older versions of H323 do not support these features.
Thanks in advance for any help.
Re: Determine H323 version
Use command
show gateway.
sh gateway
H.323 ITU-T Version: 4.0 H323 Stack Version: 0.1
H.323 service is up
This gateway is not registered to any gatekeeper
Alias list (CLI configured) is empty
Alias list (last RCF) is empty
Sankar
PS: please remember to rate posts!
Thanks for replying. I already tried the Show Gateway command. I don't receive any relevant information. All that is displayed is:
Any idea what this means?
Hall of Fame Super Gold
Most likely you are running an older IOS version.
Yeah, possibly an older ios version. Can you paste a sh version output?
sh version
IOS (tm) 3600 Software (C3660-IS-M), Version 12.2(12a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Tue 24-Sep-02 00:00 by pwade
Image text-base: 0x60008940, data-base: 0x61160000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
Cisco3660-2 uptime is 4 weeks, 16 hours, 50 minutes
System returned to ROM by reload
System image file is "flash:c3660-is-mz.122-12a.bin"
cisco 3660 (R527x) processor (revision 1.0) with 111616K/19456K bytes of memory.
Processor board ID JAB0510C053
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
MICA-6DM Firmware: CP ver 2730 - 5/23/2001, SP ver 2730 - 5/23/2001.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
3660 Chassis type: ENTERPRISE
2 FastEthernet/IEEE 802.3 interface(s)
75 Serial network interface(s)
12 terminal line(s)
6 Channelized T1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
can you upgrade a least to 12.2(46) ?
That would not give you the h323 version with "show gateway", but it _might_ resolve the one-way audio issue.
182
