Community Member
Determine Max Simultaneous Calls on 3825
Is there a way/command to determine (from the router)the maximum number of smultaneous calls that have run through a 3825 Voice Gateway? IOS is currently 12.4(19). Thanks in advance.
Hall of Fame Super Gold
Re: Determine Max Simultaneous Calls on 3825
Do you have CM ? If so, it can produce many statistics of this type.
Else, you can monitor the ISDN MIB with any snmp tools and it will produce a graph of channel usage over time.
Community Member
We have CM but I would rather determine from the router side as I am on Network Side of house and I don't want to interfere with phone guys. The ISDN MIB might work for me - do you have any additional info on it?
ISDN MIB:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=CISCO-ISDN-MIB
Watch out that if you're using MGCP, I'm not sure if that would work.
Community Member
It doesn't appear that ISDN MIB RFC 2127 is available for the 3825 platform. Do you know for a fact that it is. It all appears that it is only available for BRI connect. We currently utilize PRI.
Yes it is, you worry not. Now checking better I think the MIB is this one:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&mibName=ISDN-MIB
186
