Community Member
device CLI
I have a customer with 3 sites and a number of home workers in the UK.
The customer uses Extension mobility throughout.
The customer is asking how we can correctly show a phones location when dialling 999 i.e one of the 3 offices or home location, I have looked at Emergency responder but it seems expensive so looking at alternates.
Based on where the user is I just want to amend the CLI given to a phone when it dials out so if they log in to a phone at site A use CLI 12345 if site b use CLI 54321 etc
All the E1 links are based at main site so no local break out. Any idea if this can be achieved with out CER?
1 ACCEPTED SOLUTION
Re: device CLI
Look into device mobility for this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
Re: device CLI
java
java
144
