Device Count 7500
What does Unified Communications manager 8.x consider as part of its 7500 max device count per server?
Is it just phones?
Does it consider FXO / FXS ports?
Does is consider CTI Route points?
I cant seem to find a doc that tells me.
Thanks in advance for any insight that can be lent.
Del
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Device Count 7500
Hi Del,
In this reference, the number 7500 does apply to phones only There are other numbers for
trunks, CTI etc. that are also noted in this section of the CUCM SRND;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/callpros.html#wp1287334
Cheers!
Rob
1 REPLY
Device Count 7500
Hi Del,
Cheers!
Rob
153
