Device Info
How can we get the following info from CallManager 4.1.3 using an SQL query or some other tool:
IP Phone Model
Device Name
Description
DN
Display or Alerting Name
Bronze
Re: Device Info
To query the phone type, you can go to:
Enterprise Manager > SQL Group > Local > DB > (select the cm) > Table > Right click 'Device' > Open Table > Return all rows
tkmodel column will tell you the model.
8 = 7940
7 = 7960
6 = 7910
Re: Device Info
the numplan table contains several of the items you're asking for. device also has some of them
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
128
