Device license unit file
Does any of you have the link to get the file where is show all the license unit asign to each type of IP phone/Device
I have one excel file but is not included 7921 IP phone.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Device license unit file
Hi Filiberto,
Just to add a note to the good (correct) tips from Joel, I have attached a newer version of the DLU Calculator that includes models like the 7921.
Hope this helps!
Rob
If you already have a callmanager you can look under System - licensing - Licence unit calculator
my cm6.0 show 7921 as 4 units
:JoeL
Hi Filiberto,
Hope this helps!
Rob
Hey Rob Excellent Info (+5).
I also use the same file and was wondering if you observed this - (sorry for going out of track)
1) ATA 186 - DLUs required for 5.0(4a) is 2, for 5.1 its 3 and for 6.0 & 6.1 its 1.
Is this really true since I guess with CUCM 6.X it still requires 2 DLUs.
2) Mobility Enabled End Users - for 6.0 2DLUs, for 6.1 4DLUs.
There is a confusion again because Mobility still requires only 2 DLUs if I am not mistaken.
3) Mobility Enabled End Users (Adjunct) - 6.1 requires 2 DLUs.
I guess its 1.
What's your take on this.
BTW just observed Spell Check is now incorporated while typing the posts.
-> Sushil
thanks Rob,
very helpful file,
I hope cisco publish soon this file including CM version 7
181
