Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Device mobility and ext mobility
Anyone knows if there is a link between device mobility and ext mobility. Ex. one person move from one location/site to another, log in to a phone with ext mobility to get his/her phone profile/number. Would it be possible to use device mobility, ex that the phone will use the local pstn gw for external calls?
1 REPLY
Re: Device mobility and ext mobility
look into the SRND there you will see the considerations for that
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
157
