Device Mobility question
For Device Mobility, why does the system not allow CM Groups to be one of the "Roaming Sensitive" parameters? To me, this seems like one of the biggest areas of benefit for Device Mobility(automatic distribution of phones to nearest CM subscriber based on subnet). But it isn't really mentioned in documentation.
The CMG even shows up in the "View Current Device Mobility Settings" popup for a phone (at least, it does in 7.0)... implying that perhaps there is support for it somewhere. Am I missing something here?
Green
Re: Device Mobility question
Hi Frederick,
When you are configuring Device Mobility Info you have the Device Pool option, we can configure the CMG there, you may create specific Device Pool for Roaming Devices, so once Device is in matching subnet will aquire that Device Pool parameters, not sure if this what you were referring?
Let us know
The problem is that the CMG does not seem to be included in the parameters that the device picks up from the roaming device pool... the CMG stays at the setting specified by the device's home device pool.
145
