You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
device mobility vs. emergency responder
Hi All,
with the new feature "device mobility", do we still need emergency responder? what's the advantage to have emergency responder beside email and call notification to security desk when we can use "device mobility"?
thanks
Alex
  • IP Telephony
Hall of Fame Super Red
Re: device mobility vs. emergency responder
Hi Alex,
Excellent, thoughtful question my friend
Although Device Mobility may help mitigate the problems
associated with "nomadic" phones and 911 services by routing
calls out the proper "local" gateway it does not eliminate the
need for CER in my mind.
If you are in a location on a large campus and someone has
a serious health emergency, a call from a properly configured
Device Mobility "nomadic' phone may reach the proper PSAP
centre but they will only know to dispatch an Ambulance to the
campus itself. With CER they will dispatch Emergency personnel
to the "actual" room on campus where the person is in trouble.
The saving of time by a proper dispatch location may, in fact, save
the persons life. Something to think about.
In my mind these two great services are mutually exclusive and should
be used in conjunction with one another, not as separate entities.
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Hall of Fame Super Silver
Rob is absolutely right, Device Mobility does not replace CER, think of a scenario where there are multiple zones within a building that uses the same trunks for outbound calling, device mobility will let us ensure phones moved to this building will use the right trunks, but does not ensure 911 calls go out with the proper ELIN, sure you can force it with creating a mobility info group for every subnet and match subnet to ERL, but that would be extremely difficult to manage, require a lot of configration and would not be applicable to all networks.
HTH,
Chris
179
