Device Mobility
Hi All,
We are running CUCM 6.X in a cluster environment. There's one publisher and few subscribers in this cluster and phones on the respective locations register with the respective subscribers which are sitting on those locations.
I configured device mobility. When a phone moves from one location to another, on the display it says the device is in a roaming location but it does not change the device pools and register with the local subscriber. It registers with the previous subscriber.
I want to know whether when a device moves from one place to another is there a possibility of registering that device on the local subscriber of that location without manually changing the device pool of that phone to the local device pool.
Thanks.
2 ACCEPTED SOLUTIONS
Re: Device Mobility
Device mobility don't change where is CM information provided.
DM will use some settings from dial pool:
Roaming Sensitive Settings
The parameters under these settings will override the device-level settings when the device is roaming within or outside a Device Mobility Group. The parameters included in these settings are:
Date/time Group
Region
Media Resource Group List
Location
Network Locale
SRST Reference
Physical Location
Device Mobility Related Settings
The parameters under these settings will override the device-level settings only when the device is roaming within a Device Mobility Group. The parameters included in these settings are:
Device Mobility Calling Search Space
AAR Calling Search Space
AAR Group
More info you can find: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/devmobil.html
rate if this help
Re: Device Mobility
DP is the only way to give phone information about CMs I'm afraid.
Re: Device Mobility
Date/time Group
Region
Location
Network Locale
SRST Reference
Physical Location
AAR Group
rate if this help
Re: Device Mobility
Thank you for the reply.
Is there any other method to do this without manually changing the device pool?
Re: Device Mobility
Re: Device Mobility
Thanks.
480
