device pack 9.1.2.12028-1 bug?
Installed device pack device pack 9.1.2.12028-1 last week. Now I am getting complaints from 7962 users with headsets stating that while in headset mode they cannot transfer a call. They are stating that when they press the transfer button it simply puts the person on hold with no ability to dial digits.
If I take them out of headset mode the transfer feature returns.
If I downgrade from SCCP42.9-3-1SR4-1S to SCCP42.9-3-1SR2-1S transfer functionality retuns in headset mode.
Any ideas? Or is this a bug?
  • IP Telephony
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi there, I'm not sure how
Hi there,
I'm not sure how this is marked as "fixed" .....crying
Problems transferring/answering calls when using headset with 79XX phone
CSCun26289
Symptom:
- When a user attempts to transfer a call, the original call is placed on hold, but the user is not able to dial the transfer destination.
- When a user already has an active call on their phone, they are unable to answer a new incoming call. The original call is placed on hold, and the new call is simply disconnected.
Conditions:
- Using a headset with a 7900 series phone
- Running firmware 9.3(1)SR4
Workaround:
- Do not use a headset
- Rollback to 9.3(1)SR3 or earlier
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
Ok I can confirm that when I
Ok I can confirm that when I downgrade the phone from SCCP42.9-3-1SR4-1S to SCCP42.9-3-1SR2-1S the transfer functionality returns.
Hi there,
CSCun26289
Symptom:
Conditions:
Workaround:
Cheers!
Rob
I think this is a fantastic
I think this is a fantastic workaround: - Do not use a headset
Really?
Hi there, Tell that
Hi there,
Tell that "workaround" to your users laugh probably won't fly I'm guessing!!
I might open a TAC case to see if they have a "fixed-in" version available for special download.
Cheers!
Rob
I know this is 4 months old,
I know this is 4 months old, but I just wanted to follow up. Had the same issue on 79XX phones with headsets, today.
Opened a support ticket with TAC, received a fixed firmware version.
The Cisco Caveat Id for this issue is:
CSCun26289
The updated version is SCCP45.9-3-1ES27S
The 'transfer' seems a little off still, but it does work. The headset almost disconnects, then immediately reconnects. Seems to add about 2 seconds to the transfer time once users are used to the issue.
1075
