Device Pack for 6.1
Is it possible to install device packs during the 6.X install? I know that you can install SR's during install. any help would be appreciated. Thanks
Jason
1 ACCEPTED SOLUTION
Re: Device Pack for 6.1
no, only SRs or ES can be applied during the install.
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
javalenc
java
98
