Community Member
Device Pool Configuration - CUCM 7.1.5
Need some clarification for below-mentioned points.
Whats the Incoming Calling Party Settings like National/International/Unknown/Subscriber Number
Whats the difference between Incoming Calling Party Settings given in Device Pool and Gateway?
Whats the Local Route Group mentioned in Device Pool Page...... Thanks alot
1 REPLY
Hall of Fame Super Silver
Re: Device Pool Configuration - CUCM 7.1.5
There is no difference, it's a preference to either use it at the GW level or Device pool.
As to local route group it is used for local route group routing where the device pool assigned to devices such as phones controls which route to take. Basically simplifies amount of route patterns required. Take a look at SRND for more details.
Chris
298
