device pool
vortiz_mnet
hi, somebody know about how many device pools, callings sercha space and partitions are supported in MCS 7835 Rel 7?
best regards
Jaime Valencia
There are no hard limits for any of those, the real limitation is how manageable a system with hundreds of each can be and the HDD size as each element takes space in the DB.
Bear in mind this:
A Unified CM cluster with a very large dial plan containing many gateways, route patterns, translation patterns, and partitions, can take an extended amount of time to initialize when the Cisco CallManager Service is first started. If the system does not initialize within the default time, there are service parameters that can be modified to allow additional time for the configuration to initialize. For details on the service parameters, refer to the online help for Service Parameters in Unified CM Administration.
And the 1024 char limit in the CSS.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
