Device Pool
Can anyone advise why the default device pool showing red status for the small PC icons.
Does this mean the pool is not operational for use. IE if I add it to a ip communcator phone will it work in the red status.
  • IP Telephony
Hall of Fame Super Silver
Re: Device Pool
Not sure what icon you refer to, but my guess is that it indicates that this DP cannot be deleted.
Chris
Re: Device Pool
It is a little PC icon that looks like two small computers next to the device pool name and if this is shaded in red does it mean that the device pool is not operational, what does the colour indicate?
Bill
Bronze
Re: Device Pool
In CCM 4.1, mine looks like this, and it's just an icon that happens to be red. The icons aren't used to indicate status. Instead, look at the "Status" field for status of phones, Gateways, and CTI route points.
Re: Device Pool
Thanks for this
145
