Device Pools and SRST
All,
I just ran across a situation where a site was built out with 2 Device pools.  Site-Name and Site-Name-SRST. I can only come up with a reason for having these device pools being the SRST licensing.  If they have 50 phones but only purchased a 25 pack license for SRST then they can determine which phones get go into SRST mode.  Would there be any other reason to do this?
All replies rated.  Thanks in advance!
1 ACCEPTED SOLUTION
Going by the names, it sounds
Going by the names, it sounds like that's the case, if you've already compared them, and that's the only difference, then there you have it.
java
if this helps, please rate
www.cisco.com/go/pdi
1 REPLY
java
40
