Silver
Device profile on two differents location.
Hi all,
I am facing the following scenario in one CUCM 6.1.2 environment:
We have two sites in two differents countries : Country_A and Country_B.
The Cluster and Gateways are in country A. In Country B, there is only one WAN router (no access to the local pstn).
One mobile worker logs with its Device profile (associated to its DN) either on a phone on country A or B.
When user is logged in a phone in Coutry A the CSS allows him to call a certain set of numbers (especially the numbers in coutry B via the local GW).
But when in located in coutry B, we want to avoid user calls local numbers (because the call will go through the WAN and will be charged to the Country A Gateway).
When using EM the partitions of the line CSS will add with the device ones (result being line CSS partitions followed by phone partition).
Do someone been facing this scenario? Is there any chance to reach this with the same device device profile used ?
Thanks in advance for your ideas.
Kind regards.
Karim
Telindus FRANCE.
Re: Device profile on two differents location.
Look at device mobility
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/devmobil.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
Silver
Hi Java,
Many thanks for your feedback.
So per my understanding I should implement here the Line/Device approach with the mobile user having both Device Mobility and Extension Mobility enabled in his profile.
Have a nice day;
Regards.
Karim
137
