Device Updates
When you download a device update into Call Manager where do you get the Load Information so you can put it into the Device Defaults Configuration page?
1 REPLY
Silver
Re: Device Updates
If you are downloading a devpack, I believe this should update the device defaults page for you. If you are using the zip file, then you have to do that yourself.
Either way, if you read the release notes, you will see the file names present in the upload. Follow the format that was there before and simply replace with the new version.
By format, I mean, sometimes they want a .BIN/SBIN at the end, sometimes they don't.
Lelio
112
