DevicelistX
jamieparr
Hi all,
I am having a problem in application integration. My problem being that I have no Devicelist. When I navigate to http://x.x.x.x/CCMAdmin/reports/devicelistx.asp I get "the requested resource is not available".
Can anyone tell me how to enable this? Anything I should have activated?
I am using call manager 6.0
Jamie
dezoconnor
Level 4
Level 4
Sorry Jamie, what application are you trying to integrate? What are you expecting to see from the URL you refer to?
Thanks for the reply.
I am trying to intiate a simple remote execute, it falls down querying the device name. This I believe is due to there being do devicelistx webpage. When I navigate to it I get no page. I think I should see some sort of xml?
Thanks for the answer.
That will be why I can't access it!
