08-03-2007 05:31 AM - edited 03-14-2019 10:55 PM
Hi everyone
I have 2 CM(Publisher and Subscriber). Default TFTP is CM(P). How can I configure a DHCP 66 option to make a CM(S) an alternate TFTP? (DHCP is under Linux - ISC DHCP Version 3)
PS: I don't know the exact syntax, because currently DHCP 66 option contains only 1 string with ip-address of CM(P).
08-03-2007 06:13 AM
DHCP option 66 only allows for one IP address.
DHCP option 150 allows more than one IP address.
Setup your DHCP server to use option 150 instead.
08-06-2007 02:07 AM
Thanks, this realy solved the problem
08-07-2007 05:29 AM
Can't rate your post (probably browser problem) - but it was helpful
