DHCP 66 option - need help
Hi everyone
I have 2 CM(Publisher and Subscriber). Default TFTP is CM(P). How can I configure a DHCP 66 option to make a CM(S) an alternate TFTP? (DHCP is under Linux - ISC DHCP Version 3)
PS: I don't know the exact syntax, because currently DHCP 66 option contains only 1 string with ip-address of CM(P).
Anonymous
N/A
Re: DHCP 66 option - need help
DHCP option 66 only allows for one IP address.
DHCP option 150 allows more than one IP address.
Setup your DHCP server to use option 150 instead.
Thanks, this realy solved the problem
Can't rate your post (probably browser problem) - but it was helpful
453
