04-08-2009 11:52 PM - edited 03-15-2019 05:23 PM
hii
We are using Cisco ip phone 7902 in our network and we made router 3845 as dhcp server for all phones
we are configure dhcp server in router steps are
Router(config)# ip dhcp pool name
Router(dhcp-config)# host address [mask | /prefix-length]
Router(dhcp-config)# client-identifier unique-identifier
Router(dhcp-config)# hardware-address hardware-address type
but still we cant bind my ipphone ip add. when we restart ip phone it's change ip ip add..please help me??
04-09-2009 12:21 AM
configure a network first for the dhcp and also option 150 for tftp.
check this:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/srs_wlan.html#wp1333223
04-09-2009 02:42 AM
hii,
thank you for your response but one thing is that i want to bind ip add with mac id so i want that solution how it is ???
if i create seprate pool for each ip phone then that is 3000 ip phone in our network ...
04-09-2009 02:54 AM
Why do you want bind IP with MAC address ?
04-09-2009 05:58 AM
Did you preface the 12-digits MAC address with a 01, in the format 01XX.XXXX.XXXX.XX? That, apperently, is the format that the Cisco DHCP requires.
04-09-2009 08:49 PM
hii,
we want our ip phone should have uniq IP add. so we can monitor IP phone ...
it's also possible through static IP add but in our 7902 IP phone there is no display only we can hereing voice and give IP but this is very tough process..so we want to bind it in our dhcp server....
04-09-2009 08:51 PM
You do not need a static IP to monitor phone. Doing so only introduce unnecessary management overhead, and none of the large installations in the world does that.
Monitoring is better done by either MAC address, or the extension number.
