DHCP on CCM 6.0
044102947
Hi all, i have installed CCM 6.0 but i have problems with installing DHCP server. My CCM is on 192.168.150.0/24 network, 1.what should i enter on Subnet IP Address field. 2.Should the DHCP Subnet be from CCM 192.168.150/24 network or another. Thanx in advance.
dfokin
Hi!
Assuming, that you configure DHCP on the CCM itself. In this case you must enter 192.168.150.0 in the Subnet IP Address field.
I suppose, that this CCM will support IP Phones only in the same subnet -- so the DHCP Subnet should be from CCM 192.168.150/24 network.
Good luck!
