Community Member
DHCP related query and answers
DHCP- Dynamic Host configuration protocol
DHCP is also known as BOOTP
DHCP uses DORA process
D- DHCP Discover Packet to the DHCP Server
O- DHCP Offer packet to the DHCP Client
R- DHCP Request to the DHCP Server
A- DHCP Ack to to the DHCP Clent
----------------------------------------------Some IMP Questions and answers--------------------------
Q. IF DHCP server is on another network then how IP phone get IP address?
When IP Phone reboot or Connected to Switch IP Phone send DHCP request to DHCP server, If
DHCP server is not available and Router connected to IP Phone configured as IP Helper then
Router take request from IP Phone and send request to DHCP server connected to other network.
To allocate IP address with correct IP pool router send IP address of interface, on which interface
request is received.
Q. Define DHCP OPTION
DHCP is also configure for device with more information called option.
IP Address               From Scope     192.168.1.23
Subnet MASK          Option 1          255.255.255.000
Default Gateway       Option 3          192.168.1.1
DNS Server              Option 6          8.8.8.8
SIP Server               Option 120       192.168.87
TFTP Server             Option 150      192.168.1.88
VLAN ID(802.1Q)     Option 132        2
L2 802.1p Priority    Option 133        6
L3 Priority              Option 134        46
BOOTTP/DHCP option
http://www.networksorcery.com/enp/protocol/bootp/options.htm
Q. Initial IP Discovery process start with Brodcast or Not ?
--> Yes
Q. How you can check IP config on Windwos? IT help to understand DHCP flow use Wireshark and interface with your LAN card.
--> Goto START/RUN CMD(Command line) > ipconfig /all >> gives current IP address,Subnet mask,default gateway, MAC address
          ipconfig /Release >> Release IP Address  After this command get IP address 0.0.0.0
          ipconfig /Renew >> Get New IP Address    After this command get new IP Address
Q. IF you have multiple subnet and single DHCP server then what needed on Network router to assist to give IP address.
--> IP Helper command must be configured on router, so router send reuest to DHCP server on another network.
Q. Group of IP address configured on DHCP server is called as ?
--> SCOPE
Hello Sandeep, in this case the ip request would be recieved from the same voice interface on which the ip helper-address was assigned.
By using the ip helper-address command, a router can be configured to accept a broadcast request for a UDP service and then forward it as a unicast to a specific IP address
Br
Nitin Kharbanda
Community Member
Thanks for additional information
317
