Dial 8 for an outside line
A customer wants to dial 8 for an outside line. Right now it's a 9. I checked the route plan report and they have about 40 extensions that start with an 8. Some are for call park, voicemail ports, pickup group, and 800 is a route to the voice gateway.
Do I have to reconfigure each of these extensions to start with say, a 7, to be able to dial an 8 for an outside line? Or is there a faster way.
  • IP Telephony
1 REPLY
Re: Dial 8 for an outside line
Jake,
You don?t ?necessarily? have to renumber all your admin DNs; however, it is strongly, strongly suggested for the following reason: In your route plan, all your internal #s will not provide dial tone after a caller hits the first ?8? on the key pad, but when they hit ?8? for an outside line and use route pattern?8?.XXX-XXXX, they won?t receive secondary dial tone until they?re half-way through the number (if you?re using 4-digit DNs). This would freak most phone users out.
The other problem would be if they dial an outside number 8.1234567, if you have an IP phone with 8123, it will call the phone first.
These would be your two biggest problems that would motivate you to renumber everything else, or perhaps use "7" as the outside access code.
342
