Community Member
dial a 1 with long distance companies? mandatory?
SOrry, this is not really a callmanager or CME questions. Simple telephony question. Do all Long distance company require you to dial a 1. or is it just some long distance companies. If this is not mandatory for all long distance companies do any one know any specific companies that don't require the "1".
Thank you
1 ACCEPTED SOLUTION
Re: dial a 1 with long distance companies? mandatory?
Generally most telcos require dialing a +1 (our country code) for long distance calls.
However, you can order a AT&T dedicated long distance circuit (full voice T1) that you can only send 10-digit calls to. They don't want the 1 on that type of circuit. Some providers also may request you prefix all calls with a character (for example 9). You have to confirm with the carrier, but generally North America sends long distance by dialing +1.
Hall of Fame Super Red
Hi Shir,
These Access Codes (0 or1) are really set up as part of an "overall" Standards based Numbering Plan, not by the Long Distance provider. So to complete any "Offnet" call these Standards have to be met before the call can be routed through the PSTN.
Although the International Telecommunication Union (ITU) has attempted to promote common standards among nation states, numbering plans take different formats in different parts of the world. For example, the ITU recommends that member states adopt 00 as their international access code. However, as these recommendations are not binding on member states, some have not, such as the United States, Canada, and other countries and territories participating in the North American Numbering Plan. Another significant country that has not changed is Australia.
The structure is:
Access code (either international or national) - only necessary when dialing international and "national" (non-local domestic) calls. The national access code is often quoted as if it were part of the telephone number. The most common national access code is "0", and the most common international access code "00"; in the North American Numbering Plan (e.g. the United States and Canada), however, "1" and "011" are used respectively.
Country code - only necessary when dialing to phones in other countries. It is often quoted together with the international access code which must precede it in the dial string, especially in the United States and Canada (e.g. "011-XX-YYY-ZZZ-ZZZZ"). In international usage, telephone numbers are typically quoted with the country code preceded by a "+", and spaces in place of hyphens (e.g. "+XX YYY ZZZ ZZZZ"). (On GSM networks, "+" is an actual character that may be used internally as the international access code, rather than simply being a convention.)
Area code - only necessary (for the most part) dialed from outside the code area, from mobile phones, and (especially within North America) from within overlay plans. Area codes usually indicate geographical areas within one country that are covered by perhaps hundreds of telephone exchanges. It must usually be preceded in the dial string by either the national access code or the international access code and country code. Non-geographical numbers, as well as mobile telephones outside of the United States and Canada, do not strictly speaking have an area code even though they are usually written as if they do.
Local number - must always be dialed in its entirety. The first few digits in the local number typically indicate smaller geographical areas or individual telephone exchanges. In mobile networks they may indicate a network provider in case the area code doesn't. Callers from a number with a given area/country code usually do not need to include this particular area/country code in the number dialed, which enables shorter 'dial strings' to be used. This is an issue when the number must be keyed by hand, but where the dialing is automated (increasingly common) it is not an issue - and it is arguably better to include the full number with access codes in devices that dial automatically.
From this excellent Wikipedia doc;
http://en.wikipedia.org/wiki/Area_code
Hope this helps!
Rob
Community Member
Thanks for everyone's reply. Jason, this is exactly what I was looking for. My client used to have AT&T long distance, and now they cut over to Verizon.
THey claimed we changed stuff in the call manger to force them to dial a 1. But we never changed anything but created the verizon t1's and changed the LD route list's.
Thanks again Jason. And to everyone who replied, it was all informative.
Jason,
Very informative! I never knew something like this existed. 5 points for your good work on this :)
Rob
237
