Community Member
dial issue
I have the following issue, I want to dial a log distance call number, but to make the call work I have to dial to many times until I it works.
The call goes via E1 trunk.
what can this be?
Thanks.
Are you using one or
Are you using one or multiples gateways?
Can you try adding the output of  "debug isdn q931" when you try to make the call.
Thanks.
Rolando Valenzuela.
Community Member
I only have 1 gateway. thanks
thanks.
Try gathering the output of
Try gathering the output of the command debug isdn q931
and share it with us, also, please check this reference guide about the debug above: http://www.cisco.com/c/en/us/support/docs/dial-access/integrated-services-digital-networks-isdn-channel-associated-signaling-cas/8607-isdn-disc-code.html
Rolando Valenzuela.
Community Member
Rolando, I did some changes
Rolando,
I did some changes and know im going via a intercluster and have the same issue.
thanks
24
